I pasted this from an old post back in 2008.
It's the only place that mentions this.
I'm going to purchase an Elk M1 (8EZ or Gold) soon. Being an electrical engineer and wanting custom features, I want to develop my own ethernet -> serial interface for it. I have already developed a custom interface board solution that can talk on a RS485 bus or on a RS232 bus. I see the RS232...
cocoontech.com
From the M1's keypad enter installer programming, go to Globals G44, right arrow, enter 55555 into the a: field, press ***.
Every transmitter transmission received will be sent out the RS-232 serial port in this form:
A2-Z21-A29B68-Lb0-B0-L11-L20-R0-Tp1-Tb0-M1-CrB0
A2 = address of receiver on the RS-485 keypad data bus
Z21 = zone number of transmitter enrolled in M1
A29B68 = Serial number of transmitter
LB0 = battery in transmitter is OK, LB1 = battery in transmitter is low
B0 = button data from transmitter, usage will vary according to type of transmitter
L11 = hardwire loop 1 is violated, L10 = OK, usage will vary according to type of transmitter
L20 = hardwire loop 2 is OK, usage will vary according to type of transmitter
R0 = Reed switch in tranmitter is closed, usage will vary according to type of transmitter
Tp1 = tamper switch is violated, usage will vary according to type of transmitter
Tb0 = test button is OK, usage will vary according to type of transmitter
M1 = Manufacturer of transmitter = GE, M2 = manufacturer of transmitter is Ness Security
CrB0 = CRC byte of data received at RF receiver. This is verified by the M1 when the RF data is received by it.
You can view the data with HyperTerminal or the M1SDK program connected to the RS-232 bus or the data coming out of the M1XEP Ethernet connection.
If the M1 is powered down or reset the RF data will stop until the procedure above is repeated.
