Hello all,
I have an intercom that when someone presses my button it rings in my home. I tested the voltage and while the button is pressed it reads approximately 3.5v. If I disconnect the actual bell or buzzer and press the button it reads just under 5v. So without load it's about 5 volts.
What I did, Is hook up one of the digital inputs on the Cai webcontrol to this buzzer signal, and have it programmed to email me each time someone presses the button. This works fine, get the email, the buzzer in my place makes the sound.
The problem is however, the sound level of the buzzer is very low, I would say about 75% less after I hooked up the CAi webcontrol into the mix. I tested the voltage and now the voltage is about 1.5v, this would explain why the buzzer sound is low.
How to get around this? What do I need to do and what parts do I need to have both the Cai Webcontrol and the buzzer hooked up at the same time and the buzzer sound to be louder?
Thank you for any input.
