123
File Name: ScriptMacro: Convert Premise Browser to 1024x768.
File Submitter: 123
File Submitted: 02 May 2012
File Updated: 02 May 2012
File Category: Premise
Author: 123
Contact: Support Topic
Version: 1.0
A few years ago, I described how to convert Premise Browser (AutomationBrowser) from its default resolution of 800x600 to 1024x768. The instructions can be found in this post. There are several steps involved and the process is tedious. Now it can be done quickly with a ScriptMacro.
The attached zip archive contains four files:
C:/Program Files/Premise/SYS/web/Images/TexturedWindowsXP.jpg
If you are using another Theme, you'll need to create a new background image resized to 1024x768.
Import the XDO and it will create a ScriptMacro here:
Modules > Default > Macros > PremiseBrowser > PremiseBrowser1024x768
Replace C:/Program Files/Premise/SYS/web/Platforms/Desktop/default.htm with the supplied Default.htm file. Alternately, if you have other modifications in your default.htm file that you don't want to lose, follow the modification instructions in the first section (HTML Modifications) of the original post.
Run the PremiseBrowser1024x768 ScriptMacro and it will convert AutomationBrowser's display resolution. Restart the Premise Server service so that it reads the new Default.htm file.
Please note that the Media-related dialogs will continue to display in 800x600. You'll have to replace their 800x600 background images with 1024x768 images.
Click here to download this file
File Submitter: 123
Author: 123
Version: 1.0
- PremiseBrowser1024x768.xdo (Contains the ScriptMacro)
- Default.htm (Premise Web Server's startup page)
- TexturedWindowsXP.jpg (Theme image)
- Space_1024x768.jpg (Theme image)
