davidliles
I'm running into an issue and haven't been able to figure it out.
I successfully enrolled the Pulse Worx PIM-E and exported my UPB configuration from UPStart and imported it into my Elk. I initially created a rule that would turn on the exterior lights X hours after sunset and then a second rule that would turn them off X hours before sun rise.
I noticed the rule didn't execute and after some searching here I saw a post about that trigger being unpredictable and that a specific time should be used. I changed the rule to use a hard time and noticed it still isn't executing. Is there something else I am missing?
Below is the rule I created.
WHENEVER THE TIME IS 10:00 PM
THEN TURN Outside Exterio [1(A1)] ON, FADE RATE = 0
