A question to camera security gurus. Moved thread from original.
The replacement outdoor dome I installed is an Everfocus Model EHD350/H-1. It faces SW.
Everfocus
Right off noticed that my field of view is smaller than previous dome. I need to adjust it a bit.
Noticed that I can adjust a few settings on it and would like some recommendations:
Here are the specs - will most likely unplug the heater.
Pickup Device 1/3†Sony Interline Transfer Super HAD CCD
Video Format NTSC or PAL
Picture Format 768 x 494 (NTSC) / 752 x 582 (PAL)
Horizontal Resolution 560 TVL
Video Output BNC 1.0 Vp-p, 75 ohm
Sensitivity 0.5 Lux/F=1.2
S/N Ratio Over 48dB (AGC Off)
Electronic Shutter 1/50 (1/60) ~ 1/100,000 sec.
Sync. Mode Line Lock/Internal Sync.
Flickerless On/Off switch
Backlight Comp. On/Off switch
Auto Gain Control On/Off switch
Auto White Balance Yes
Gamma Correction 0.45
Iris Level Adjustable
Lens Built-in vari-focal f=9~22mm / f=2.9~10mm
Dimensions (W x H x D) 130 x 98.8 x 130 mm / 5.1†x 3.9†x 5.1â€
Operating Temp. -40°C ~ 50°C / -40°F ~ 122°F
Humidity 20% ~ 80% humidity
Power Source 12VDC/24VAC
Power Consumption With Heater:
24VAC: 20.5W max. / 12VDC: 11.5W max.
Without Heater:
24VAC: 6W max. / 12VDC: 4W max.
Weight 1.7 kg / 3.7 lbs.
Weatherproof IP66 rated
Vandal Resistant Yes
Attached are two cropped pictures. One is old cam and the other is new cam.
I've adjusted cam to give me maximum FOV.
I am having a problem with the camera though and currently testing it in the house. It seems to work well outside for only about 15 minutes or so. Not totally sure but it shuts itself off (shutter). I can hear a "clicking" from the camera. Originally before I adjusted it noticed that night view was "flickering" from deck lighting. The next day I adjusted the FOV, line-lock is off, AGC is off, BLC is normal, Flickerless function is on and electronic shutter is on.
Yesterday noticed that it would only work for about 15 minutes then the picture would go "off". During this time I could "hear" clicking from the camera (shutter?). I brought it inside to validate its functions. It's been connected and powered on all night and functioning fine. Will test again today outside. I believe its one of the dip switch settings and the ambient sunlight which is causing the shutter to close. The lens itself doesn't ever face the sun where it is positioned today.
Everfocus
Without Heater:
