Ok, I have this problem in two locations in my house now. I am using the HAI 600W UPB dimmers in a 2-gang box with another switch in that box. In one case, the other switch is an HAI relay switch that controls a standard bathroom fan. In the second case, the other switch is a ceiling fan 3-speed control.
Here is the problem: In both locations, if the 600W dimmer switch's light is on and I turn the other device (ceiling fan, bath fan) on, the 600W dimmer switch will reset. The light goes off, the led on the switch flashes red a couple of times, and then the light will go back to it's original state. It is like the initial power surge of the fans are causing the HAI dimmer switch (which is just in the same 2-gang box) to reset.
Has anyone else seen this? Since it is happening in two separate locations, it seems unlikely that it is an isolated, bad switch. I do have a Simply Automated UPB switch sitting around, so I was going to try to replace the HAI dimmer w/ that to see if it has the same issues.
Any ideas on what to do about this? Should I contact HAI directly?
Thanks in advance for any suggestions!
Kurt
Kurt
