Humidity monitor email
siafu
Hello,
I'm trying to have the board send me one email when the humidity is above certain %, then send another email when it is below a certain %
Below is the complete code, Marked in RED, All other code is working fine.
The Email for Humidity, are not working.
Can someone please help me with this? Thank you in advance.
This board Version: v03.01.03
START
    TSTLT AIP1 4
    SET OP1 1
    TSTGT AIP1 8
    SET OP1 0
    TSTLT T3 1130
    SET OP2 1
    TSTGT T3 1210
    SET OP2 0
    XOR OP1 VAR1
    BZ  TEMPTEST
    TSTEQ OP1 1
    EMAIL 1
    TSTEQ OP1 0
    EMAIL 2
    TSTGT H1 27
    EMAIL 5
    TSTLT H1 20
    EMAIL 6
TEMPTEST:
    XOR OP2 VAR2
    BZ  DONE
    TSTEQ OP2 1
    EMAIL 3
    TSTEQ OP2 0
    EMAIL 4
DONE:
    SET VAR1 OP1
    SET VAR2 OP2
    END
siafu,
You will need to set a flag for email sent, so that it is no longer sending email for about certain humidity level.  Then you need to set another flag for below certain level. Having those two functions interlocked, so that only after sending high level email notice, it will unlock sending email for low humidity.  Similarly, only when sending low humidity level email notice you will reset the high humidity level notice flag.
here is a basic email setup,i took me a long time to get it but once you do it will be easy
Start
   set var1 0
loop:
    callsub reset
    tsteq op8 1
    callsub email
    goto loop
    end
reset:
     tsteq op8 0
     set var1 0
     ret
email:
     tsteq var1 0
     email em1
     delay 100
     set var1 1
     ret
thank you for taking the time pittom, however, I have other logit that uses those emails, here is the entire logit. the text marked in RED is the logit I'm trying to incorporate.
START
    TSTLT AIP1 4
    SET OP1 1
    TSTGT AIP1 8
    SET OP1 0
    TSTLT T3 1130
    SET OP2 1
    TSTGT T3 1210
    SET OP2 0
    XOR OP1 VAR1
    BZ  TEMPTEST
    TSTEQ OP1 1
    EMAIL 1
    TSTEQ OP1 0
    EMAIL 2
    TSTGT H1 27
    EMAIL 5
    TSTLT H1 20
    EMAIL 6
TEMPTEST:
    XOR OP2 VAR2
    BZ  DONE
    TSTEQ OP2 1
    EMAIL 3
    TSTEQ OP2 0
    EMAIL 4
DONE:
    SET VAR1 OP1
    SET VAR2 OP2
    END
sorry to sound like a broken record but what you posted dones not show  me anything anything to fix,but maby try changing
tsteq h1 27
email 5
tsteq h1 20
email 6
   TSTGT H1 27
    EMAIL 5
    TSTLT H1 20
    EMAIL 6
Hi pittom, no appologies needed, I appriciate that time you are taking trying to help me with this.
OK, I'll change the logit to what you have suggested and give it ago.
Thanks again.
I have old hottub that is out side in pa and use all winter and this is how i keep track of it.
email is sent as text to phone so i get it right a way
Code:
START
	SET RAM1 10
	SET RAM2 0
	SET RAM3 0
	SET op4 0
	SET VAR5 0
	SET RAM5 0
	SET VAR6 0
	SET VAR7 0
	SET VAR8 0
LOOP:
	CALLSUB RESETRAMS
	DELAY 2000
	TSTEQ OP5 1
	CALLSUB OVERIDE
	TSTEQ OP2 1
	CALLSUB PH_OFF
	SET OP3 VAR5
	TSTEQ CT 23:11:11
	CALLSUB BEDTIME
	TSTLT VAR1 1000
	SET VAR1 1000
	TSTGT VAR1 1041
	SET VAR1 1040
	SUB VAR1 RAM1 VAR2
	DELAY 2000
	TSTGT T3 950
	CALLSUB SEND_EM7
	DELAY 1000
	TSTLT T3 350
	CALLSUB SEND_EM3
	DELAY 1000
	TSTGT T5 1055
	CALLSUB SEND_EM1
	DELAY 1000
	TSTLT T5 700
	CALLSUB SEND_EM5
	DELAY 1000
	TSTGT T2 1000
	CALLSUB SEND_EM6
	DELAY 1000
	TSTLT T2 350
	CALLSUB SEND_EM2
	DELAY 1000
	TSTGE T5 VAR1
	CALLSUB SEND_EM8
	DELAY 1000
	TSTEQ OP1 1
	CALLSUB MANUAL_ON
	TSTLT T5 900
	CALLSUB HEAT_ON
	TSTGT T5 1000
	CALLSUB HEAT_OFF
	SET VAR5 0
	GOTO LOOP
	END
RESETRAMS:
	TSTLT T5 1000
	SET op4 0
	TSTGT T2 400
	SET RAM2 0
	TSTGT T3 400
	SET RAM3 0
	TSTGT T5 730
	SET RAM5 0
	TSTLT T2 950
	SET VAR6 0
	TSTLT T3 900
	SET VAR7 0
	TSTLT T5 1045
	SET VAR8 0
	DELAY 2000
	RET
SEND_EM1:
	TSTEQ VAR8 0
	EMAIL EM1
	DELAY 2000
	SET VAR8 1
	SET VAR5 1
	DELAY 2000
	CALLSUB PH_OFF
	RET
SEND_EM2:
	TSTEQ RAM2 0
	EMAIL EM2
	DELAY 2000
	SET RAM2 1
	DELAY 2000
	RET
SEND_EM3:
	TSTEQ RAM3 0
	EMAIL EM3
	DELAY 2000
	SET RAM3 1
	DELAY 2000
	RET
SEND_EM5:
	TSTEQ RAM5 0
	EMAIL EM5
	DELAY 2000
	SET RAM5 1
	SET VAR5 1
	DELAY 2000
	CALLSUB PH_OFF
	RET
SEND_EM6:
	TSTEQ VAR6 0
	EMAIL EM6
	DELAY 2000
	SET VAR6 1
	SET VAR5 1
	DELAY 2000
	CALLSUB PH_OFF
	RET
SEND_EM7:
	TSTEQ VAR7 0
	EMAIL EM7
	DELAY 2000
	SET VAR7 1
	SET VAR5 1
	DELAY 2000
	CALLSUB PH_OFF
	RET
SEND_EM8:
	TSTEQ op4 0
	EMAIL EM8
	DELAY 2000
	SET op4 1
	DELAY 2000
	RET
BEDTIME:
	SET OP1 0
	RET
OVERIDE:
	GOTO LOOP
	RET
MANUAL_ON:
	SET OP7 1
	TSTLT T5 VAR2
	SET OP8 1
	TSTGE T5 VAR1
	SET OP8 0
	GOTO LOOP
	RET
HEAT_ON:
	SET OP7 1
	SET OP8 1
	RET
HEAT_OFF:
	SET OP8 0
	DELAY 10000
	SET OP7 0
	RET
PH_OFF:
	SET OP1 0
	SET OP8 0
	SET OP7 0
	SET var5 1
	GOTO LOOP
	RET
