CAI_Support
Have anyone used this temp sensor probe on the SPI bus?
http://www.ebay.com/itm/400798924042
It will need to use SPIBYTE PLC command twice to read in two bytes, then put together and shift to the right.
It claims to read from -200 to +1300C. But in our tests, it is slow to respond to temperature change. Only when using soldering iron to touch the probe part, the reading changes quickly.
