You may remember my recent issue here:
http://cocoontech.com/forums/topic/20886-help-with-a-upb-four-way-switch-and-bluegreen-leds/
Which I was able to get resolved. Anyway, on the middle floor we decided to swap out the switch next to the (then working) us 240. I put in a USR in the two gang box, and another 240 on the other end of the three way switch.
I'm getting mixed results with the USR and 240 config - probably because the 240 has an 8 button plate and is configured with button one as a super multi button. But that isn't the real issue.
For some reason, the three 240s I have in a four way switch (from the previous thread linked above) are no longer working, as in they are no longer turning on the lights.
1) They all have power.
2) The LEDs change from blue to green.
3) I hear the quiet UPB sounds when I press them.
4) I can modify their configuration in UPStart - though I am finding more signal/noise issues in other areas of the house (though I now have 20 UPB devices setup, could be the issue).
Have any of you seen this before? The two gang box on the middle floor that we worked on looks fine, and the lights/neutrals all appear to be on completely different circuits. The bottom floor/garage switch which has the load attached still has blue/green LEDs but it just isn't turning anything on.
Any help would be appreciated. I think I should have followed some of the sage advice here and stuck with 1140s.
