I'm sending out ASCII strings via serial port to an Elk MV-480 board.
Each message is like 22 characters, longer than allowed message in Omnipro, So I split each into 3 omni messages.
"start" with fixed first part of message"
"variable part" which differs based on which word is to be spoken
"end" which is just carriage return/line feed ^M^J
WHEN voice2
THEN SEND *Voice Message Start* OUT SERIAL 3
THEN SEND 103 "Drive" OUT SERIAL 3
THEN SEND *Voice Message End* OUT SERIAL 3
THEN SEND 314 "Way" OUT SERIAL 3
If a trigger just sends one word, it's fine.
if a trigger is to send two or three words strung together, it's quirky on whether 2nd/3rd words get omitted or all 3 said.
A 1 second delay inserted between words by turning on a flag for a second seems to work around the quirkiness.
Any way to insert a 0.5 second delay?
Or otherwise keep the serial messages spaced apart a little? I tried sending a few "200ms silence" commands to MV-480 between words but that didn't fix the issue.
No way I'm missing to send 22 characters all at once without splitting into 2 (I did 3 for convenience, the way it breaks between fixed and variable parts of the message) messages?
Thanks!
Jeff
WHEN voice2
Thanks!
Jeff
