So I might be over engineering things here.
Here is what I want in a flood light.
Here is where I get a little crazy and need some help.
Right now my system has a RAB Super Stealth with motion detector. I plan on wiring the light so that the lights get plugged into a dimmable outlet (ZWave, RadioRA2, etc.) in the attic. The motion detector would be wired to always have power. Instead of powering the lights I would connect this to a RUBU1C or another relay and feed the 12V signal back to my Elk panel.
This way I can turn the light from 0-100% and use the programming logic from Elk. The motion detectors from RAB are pretty good and this way I can feed detection back into Elk. I could just use a standard 12V exterior motion detector. I also have cameras and could use motion detection on the cameras to turn the lights on and off and skip the motion detectors.
There are some areas a simple motion security light with dusk sensor will work just fine. However, other areas it would be nice to have the extra control.
Does anyone do this? Am I completely over engineering this?
- LED
- Good color temperature (2700k or maybe 3000k)
- Good quality- I try to only go up on a ladder when I really have to
- Ability to turn lights on/off automatically (alarm goes off, dusk/dawn, etc.)
- Motion activated
- High/low capability. Leave on all night at 10%, but when motion is detected bump up to 100%
- Dimmable- maybe I have a part and want to leave the lights on, but not full blast
