simonmason
I have an underfloor heat system in my master bathroom. It is electric, the mats are between the sub-floor and the tile - in the grout. I have been using the thermostat that comes with the system but it is not smart. So I have to live with the fact that it kicks in at the same time every day irrespective of the temperature in the room and whether we are home or not. The thermostat switches the mats on and off - 110v wiring and has an external sensor - which is buried in the floor.
I was looking at the zwave baseboard thermostats. If I were to hook one of these up then it looks like it could easily switch the mats on and off.
However, what about the temperature sensor? The existing thermostat uses the temperature sensor to switch the mats on and off based on the temperature in the floor.
If I were to switch to the baseboard thermostat then its built in temperature sensor would read the ambient temperature in the room. In my mind this is actually preferred as we put the mats in to supplement the heating in the room - the bathroom is above the garage and has only one inside wall - and the room was perpetually cold. Also, the mats have the added bonus of making it warm under foot.
Does anyone see any issue with hooking up this way and leaving the temp sensor in the floor out of the equation? Thanks.
