I installed a SA rocker dimmer a while back and just got around to adding it to the UPB system using upstart software this morning. The switch operates the local load correctly which is a 4' fluorescent fixture with two 4' tubes. I only noticed a problem after enrolling the switch via upstart.
The problem is that the switch has a signal strength of 3 and does not make an audible buzz when the rocker is pressed. I hadn't noticed in the past that it did not buzz but it has probably been that way since installed.
All of the other switched in the same garage report a signal strength of 30 and no noise on any tests. The switches are all set to report light level when pressed.
I've come to the conclusion that the switch is faulty. Do you guys know of anything else that could cause these symptoms?
Mike.
Mike.
