I have a 1 wire network using a DS9490R usb master and 8 DS18B20’s.
I am using 25 feet of cat 5 cable running to two 5 port RJ11 jacks to connect the sensors to the master. I also have a 100 ohm resistor on each of the sensors.
I wrote a java program to get the temperature every minute and display it on the screen, then save the temperature to a log file. The problem I am having it takes 12 seconds to get the data from the 8 sensors and when I try to connect 10 I get lots of errors.
I am looking for any ideas that might speed up the time to get the data and ways to add more sensors. This is my first attempt to make a 1 wire network. Thanks for any help you can give me.
