Mp333
Looking to power the ipad which is extended about 25 ft from where the power source will be with a CAT5 cable. The supplied Apple 2.1 will trickle charge the ipad slowly. Looking to bump up the voltage slightly @3A hopefully. This way it will have enough juice to charge and have the ipad on for longer durations. I found some on -bay which doe not look like has the D+&D- voltage on pin 2&3 which Apple uses to identify the charger.
Hope I can use M1RB to pass the +5v line to be able to wake the ipad using a rule.
Any body had any luck with some thing similar?
