drozwood90
Title Says it all!
Right now I've just got one from Rat Shack...
Similar to this one...but MUCH older...not "designed" for HDTV (but I bet it's the same thing as this one).
http://www.radioshack.com/product/index.js...oductId=3780245
I am curious if there is a real reason (besides the obvious) that I should get something more like this one:
http://www.radioshack.com/product/index.js...oductId=2103913
The obvious being, that the circuit is antenna, about 30-40' of RG6, Amplifier, 6-way splitter, which then feeds to the two TVs in the house.
I'd imagine, if I put the amplifier up in the attic with the antenna, I'd get better signal integrity. There is one station that comes in marginal (about 36% according to the DTV boxes). My TV's built in DTV stuff was some of the first out there and it doesn't get the lower "powered" channels.
Now, I'd rather use the direct inputs to my TV, as I can watch in 1080, unlike the "box" which down converts to 480 or worse. So, if I were to amplify the signals AT the antenna, wouldn't that be better? According to the attenuation I added, I think I'd need maybe 5-10dB of gain...which I'm hoping I can pick up by increasing the signal levels prior to the run from the attic down into the basement.
Thanks!
--Dan
Thanks!
--Dan
