Paul,
After making the .bin web page image file, you will need to use FTP utility to ftp to WebControl BRE firmware.
You can use DOS FTP command from Windows 98 or Windows XP. They will run under Windows Vista or 7. Please make
sure you WebControl's IP address is correct. Once you upload, if your web page did not work, you will have to modify
and reload. Of course, you can do factory reset on baord, it will become DHCP enabled again. Then you can find its
IP address from your DHCP server log.
This is for making BRE web page only, it does not include any firmware like web server, TCP stack, temprature sensor
control, BRE engine, etc.
To change the PLC board into BRE, you will need to send board to us for re-programming. PLC firmware
has much complex web pages with many active Java code. That is totally different from BRE firmware.
Please try FTP to your BRE board only. Let us know if that working for you. Thanks!
