[Blogs] royalj7's HA Blog - Sliding rack on the cheap
Status
Not open for further replies.
CT Droid
CT Bot
As i mentioned in a previous entry, I was having a bit of a hard time deciding how to secure my rack so it was accessible but also not always in the way. So I got some heavy duty bottom mount drawer slides and screwed two 2x4 runners to one side. I then anchored the slides/2x4 assembly to the floor. Moved the rack to sit atop the 2x4 and secured it. Now I get a sliding rack for a fraction of the cost. Couple things though. One, the sliding motion isn't all that smooth. I need to pull/push it from a low center of gravity to get it semi-smooth. Also, the slides and 2x4 add about 4" to the rack height, so that could be a problem if you are space limited. All and all I'm pretty happy with the solution...now if I could just get my Nuvo Music Port to work as well.
The slide attached to the 2x4
The assembly mounted to the floor (used tapcons to anchor)
Rack secured to the sliding rails, extended
Sliding rails retracted
Status
