Carrier Edge T-Stat intergation w/HAI OmniProII
je1058
I have an Omni Pro II that I would like to intergrate with a Carrier HVAC system which is currently using an Edge thermostat. The TStat seems to be wireless and communicates with a transceiver mounted in-line with the HVAC inside unit. Is there a way to integrate the OmniProII with this to allow either usage of the Carrier T-Stat or to allow usage of one of HAI's T-Stats?
Here's a link to the installaion manual: http://www.favret.com/pdf_files/thermostats/tp_pac_2si_install.pdf
