123
"Sound Effects" is enabled by default in Premise Browser. To have it disabled by default:
The "Dim Screen" menu item is located here as well. If you have no need for it, Export and delete it.
- In Premise Builder, click Modules in the Shortcut Bar.
- Navigate to: Modules > AutomationBrowser > Core > Classes > WebSessionEx > BrowserSounds
- In the Properties window, set DefaultValue to false.
- Navigate to: Modules > Plugins > Components > TaskList > CurrentItem > SoundEffects
- You will be deleting this item. If you ever want to restore it, you should Export it first. Right-click SoundEffects and select Export. Click OK and provide a suitable file name.
- Press the Delete key to eliminate the SoundEffects item.
