Hey everyone.
I'm building my first one-wire network with two sensors (one DS18S20 temperature sensor and one DS2406 to be used as a relay).
my setup:
I'm using HomeSeer 2
I use xAP hub, xapmcs1wire and mcsxap to communicate between the sensors and homeseer.
I use xfx viewer to monitor my xap traffic.
my problem:
Even though my temperature sensor works perfectly in xapmcs1wire ( i see the temperature change every few minutes and there is a green light under the "P"), I get the following errors appearing in xfx viewer every few minutes:
The only time homeseer updates the thermometer value is when I type "mcs.onewire.*:>" in "BSC Target Address Mask " then pressed "Query BSC"
Note that the ds2406 works perfectly and has no errors
Any idea?
According to page 119 of this pdf,
native TMEX error code -12- means "FILE_READ_ONLY: trying to write a read file handle"
cheers
my setup:
my problem:
v=13
hop=1
uid=FF.0005:00
class=Homeseer.Event
source=mcs.OneWire.PATATE-38602B5A
Event.Log
Time=2010-03-25 21:23:49
Type=xapmcs1Wire
Data=Sensor 13000801D2F09F10 (mcsxap1wire_1820_temp) com.dalsemi.onewire.adapter.OneWireIOException: native TMEX error -12 at 320
xap-header
v=13
hop=1
uid=FF.0005:00
Event.Log
Time=2010-03-25 21:17:29
Type=xapmcs1Wire
Data=Sensor 13000801D2F09F10 (mcsxap1wire_1820_temp) com.dalsemi.onewire.OneWireException: 1-Wire Adapter communication exception at 320
Any idea?
cheers
