I have my XEP set to a static IP address and all worked fine until we picked up Verizon FIOS and replaced our router. New router operates on a different subnet, so while my router address is 192.168.1.1, the XEP is set to 192.168.0.40. I am away from my house and I have no ability to physically change setting. I want to access my virtual keypad with the XEP, but when it is in the x.x.0.x subnet and not the x.x.1.x like my router, I am stuck. ElkRP can "find" my XEP but I cant change its IP address (I cant "connect" to the XEP to change settings). I know a fix would be to get my router to the x.x.0.x addresses, but I am afraid to do that remotely because I might lose access to the network in the process (I am getting in from a screen share on a computer with IP x.x.1.2. I would need to simultaeously change the router and PC IP addresses - if I get one and not the other I am locked out).
Bottom line question is can I communicate with the XEP at a different subnet than my router? Is there a setting on the router that might facilitate?
