VodunAutomation
Hey all,
This is my first post, although I'm sure it won't be the last.
I've recently installed a Elk M1 Gold system making use of both wired and wireless devices. One such device is GE's Crystal Wireless recessed door contacts.
I'm experiencing issues that are not making much sense to me however. One of the door contacts (main door) keeps triggering the alarm at night when the system is armed. It works fine when the system is not armed (does not have any "phantom" openings), but randomly during the night the contact will "open" causing the alarm to go off (in stay mode or away).
Right now I'm travelling for work, so can't really troubleshoot as such. I plan on bypassing the front door when I get home to see if it is indeed an issue with the contact/programming or something internal in the system (maybe even the wireless receiver), and hope that it is not.
I was thinking it could be the battery (small chance, new contact and battery), but then the signal would be randomly dropping when the system was unarmed as well (and it is not). I thought maybe there is a large enough gap between the magnet/sensor that when wind blows it opens the contact, but the contact is perfectly lined up and the door doesn't budge if I push on or pull the door,
So that has me thinking it "may" be with how the point is set up via the RP2 software. Currently it is configured as being "EOL Supervised/RF", I'm curious if this is right or should I have it configured as "Normally closed"?
Any other suggestions?
***Side note***
Currently the system has no automation/rules set up as it's a work in progress. Only the devices (few motions, door contacts) are set up and operational, so I can't see there being anything wrong there.
Thanks everyone, I appreciate the help!
***Side note***
