<html>
<head>
<title>MJPG Live Demo</title>
</head>
<body>
<center>
<h2>Motion JPEG image</h2>
<!-- Cut from here to the end of image display comment -->
<!-- Note: If you do not see a JavaScript below in the view source window you must -->
<!-- first save the html file from your browser, then open the saved -->
<!-- file in a text editor, for instance Notepad.-->
<script LANGUAGE="JavaScript">// Set the BaseURL to the url of your camera
// Example: var BaseURL = "http://172.21.1.122/";
// Since this file is located inside the unit itself, no base url is specified here
var BaseURL = "http://[myCamera]/";
// DisplayWidth & DisplayHeight specifies the displayed width & Height of the image.
// You may change these numbers, the effect will be a stretch or a shrink of the image
var DisplayWidth = "320";
var DisplayHeight = "240";
// This is the filepath to the image generating file inside the camera itself
var File = "axis-cgi/mjpg/video.cgi?resolution=320x240";
// No changes required below this point
var output = "";
if ((navigator.appName == "Microsoft Internet Explorer") &&
(navigator.platform != "MacPPC") && (navigator.platform != "Mac68k"))
// If Internet Explorer for Windows then use ActiveX
output = '<OBJECT ID="Player" width='
output += DisplayWidth;
output += ' height=';
output += DisplayHeight;
output += ' CLASSID="CLSID:745395C8-D0E1-4227-8586-624CA9A10A8D" ';
output += 'CODEBASE="';
output += BaseURL;
output += 'activex/AMC.cab#version=2,0,21,0">';
output += '<PARAM NAME="MediaURL" VALUE="';
output += BaseURL;
output += File + '">';
output += '<param name="MediaType" value="mjpeg-unicast">';
output += '<param name="ShowStatusBar" value="0">';
output += '<param name="ShowToolbar" value="0">';
output += '<param name="AutoStart" value="1">';
output += '<param name="StretchToFit" value="1">';
output += '<BR><B>Axis Media Control</B><BR>';
output += 'The AXIS Media Control, which enables you ';
output += 'to view live image streams in Microsoft Internet';
output += ' Explorer, could not be registered on your computer.';
output += '<BR></OBJECT>';
} else {
// If not IE for Windows use the browser itself to display
theDate = new Date();
output = '<IMG SRC="';
output += BaseURL;
output += File;
output += '&dummy=' + theDate.getTime().toString(10);
output += '" HEIGHT="';
output += '" WIDTH="';
output += '" ALT="Camera Image">';
document.write(output);
document.Player.ToolbarConfiguration = "play,+snapshot,+fullscreen"
// document.Player.UIMode = "MDConfig";
// document.Player.MotionConfigURL = "/axis-cgi/operator/param.cgi?ImageSource=0"
// document.Player.MotionDataURL = "/axis-cgi/motion/motiondata.cgi";
</SCRIPT>
<!-- End of image display part -->
</body>
</html>
