What labels work best for cat5?
The heat shrink are nice, but very expensive. I use the flexible nylon tape. With the 5000, you can print a "wrap" pattern, which prints your text sideways, multiple times across the tape. So when you wrap it around the cable, you can read the text from any direction.
For example, if you imagine an invisable vertical tape behind the text below, the wrap would print like this:
MBR Cable
MBR Cable
MBR Cable
MBR Cable
MBR Cable
MBR Cable
MBR Cable
MBR Cable
So when that gets wrapped around the cable, you will see MBR Cable 3 or 4 times around the cable. I hope that makes sense.
