Hello all.  I have an Elk M1 systems that I'm just getting around to wiring up.  We built the house 4 years ago and I did all the wiring.  Life got in the way and I didn't get around to wiring it until now.  Anyway... I'm taking it slow and doing one thing at a time.  All is working well until today.  I'm wiring all the glass break sensors (6 of them) and I'm getting some weird happenings.  These are Honeywell FG-1625RFM models.  Once I got everything hooked up, I cycled the system and now about every 3 or 4 seconds, the system goes into violated mode.  I have them set up as burglar perimeter instant, normally closed.  Using ElkRP, I can check the status and all of the sensors seem to be acting funny.  The state shows short (-) and the volts is jumping around from .2, .3, .4 up to 4 or even higher and occasionally the zones violate.  I pulled one out of the ceiling and everything seems to be wired correctly (did that part 4 years ago).  The LED flickers as if it's detecting an event when I make loud noises or scuff my finger across the opening (as it should according to the directions).  I have all of these powered separately from the system through a PD9HC.  I wouldn't think that would affect it.  Any ideas on what is happening here?  Any help is much appreciated.
Shane
Shane
