I have installed the Elk M1 panel and have had it up and running for about 6 months with no problems. It controls all security (wired and wireless sensors) and smoke detectors, along with three Aprilaire thermostats. It is time to add lighting controls. The house is approximately 4000 sq. ft., mostly on one level. The power is two 150 amp panels running off one meter pan, single phase. I really only need to control about 5-6 light switches and a few outlets. I have been looking into the Insteon ISY994i but not sure if I should go with the ISY994iZW for future lighting options. I would order either with the dual band PLM.
The real questions are: is this overkill and should I just go with UPB, or is the square footage of the house a problem, or is UPB technology fading out. If you would recommend Insteon is the ISY994iZW the right way to go over the ISY994i.
Hope this is the right forum.
Thanks!
Thanks!
