Home Renovation - Structured Cabling Time
euphline
Greetings!
In the next couple of months, we'll be embarking on some significant renovations at my 1920's-era Dutch Colonial here in Baltimore. Primarily, we're doing bathrooms, but because they're one atop the other, I'll have walls, ceilings, and floors "open" from the basement to the attic, over the course of the project. (The bathrooms, conveniently, are located in the center of the house). I figure now's the time to run loads of cables from the basement to the attic, and to install them in a number of rooms, while I'm at it. I have visions of grandeur and the budget of a peasant, but if nothing else I'll get all of the cables in place, ready to terminate as appropriate.
I have put together a diagram of everything I'm thinking of doing...
A little ambitious perhaps, but I'll be doing the labor myself, and in the end, copper's (relatively) cheap.
The only pieces currently in place are the DSL Modem, router, switch, wireless access point, SIP PBX and the MythTV Backend. Right now I do most of what I need to with a wireless backhaul from the basement to the upper floor. Not pretty, but it's relatively functional.
My questions are:
  • Everything look right?
  • Anything missing?
  • I'm tempted to run the door/window sensors through the punchdown block to help provide some "order". Thoughts?
I'll note that yes, I'm aware that some components could happily use CAT5. I really don't want to run both CAT6 and CAT5 in the walls, so CAT6 takes the day.
Your thoughts are much appreciated.
-jbn
I notice you have the Cat6 punchpown panel and then the keystone path panel. That might be a bit overkill..it's pretty unlikly you'll be 'patching' that frequently in your hold.
You could terminate the cat6 cabling directly in cat6 keystones in the keystone path panel...
I'll disclose i don't have a system installed in my house but have been researching quite a bit for my upcoming project.
My plan it is terminate all the field wiring onto either keystones in a keystone based panel or have dedicated panels for cat5/6 and coax..keep in mind that keystones are not cheap and in the you'll end up having to do a whole lot more terminations to get that full patch functionality eventhough you may hardly ever use it...
My plan is to terminate the wiring close side of all wiring into these panels and terminate the opposite side on an as needed basis...many time i may not need 2 RGQS and 2 Cat6 in a room...if i find the need THEN i'll spend the money on keystones and put in the labour to terminate it...untill then it's just hidden in the wall...
I am lookin for some blank RJ45 connectors in red color or something like that to 'plug' the cat5/6 slot that are not terminate at the other end...this to prevent me from accidentialy making one hot if the wire had a short (quite possible since it's not terminated) it could damage the switch/router..
Video? Is that going to be handled by baluns? It is much cheaper to run precision coax cable (that is different than the regular coax) while you can rather than buying baluns. Personally I would recommend 5 wires to each location for RGB and analog sound.
You still need RG6 for cable, antenna or sat feeds to each TV.
Any chance of wanting CCTV in the future? If so run RG59, 18-2 for power and cat5e for possible IP cameras.
Video is entirely IP, served up by MythTV. I am considering some CCTV - I'll expect to do IP cameras w/ POE.
-jbn
