AceCannon
In my planning for my DIY home AV distribution and automation project, I had initally planned on Aprilaire 8870 thermostats controlled by CQC or Elk.  Then I saw relatively inexpensive electric dampers and the gears started turning in my head. . .  You know how it is, I'm sure.  One controlled thermostat on each floor just doesn't sound as fun anymore.
Issues I have identified:
1. A zone controller can be used with cheapo, standard thermostats in each zone - but I don't think I could easily integrate this with my plan of a CQC diagram of the floor plan. Temps in each zone should be displayed and setpoints should be changeable on the interface viewer.
2. Temperature monitoring can be done in multiple zones with Elk keypads, Elk temp sensors. And I have read about folks using 1-wire setups for more economical monitoring. But then I am stuck programming my own logic for zone controlling, dampers, safety shut-off for extreme temps in bypassed air (when only one zone's duct is open). My understanding is CQC does not at present have a driver for a zone controller.
3. The Elk could easily control the dampers with relays. Manually shut off zones that won't need cooling. But that isn't nearly as elegant as being able to set a certain zone's target a few degrees different from other zones and have the dampers open and close appropriately. Someone has shared a set of Elk rules that attempt to mimick zone controllers, but it isn't clear to me how well this is working.
In summary, it seems to me that zoned HVAC solutions for the DIY'er wanting to have graphical representation in CQC may not exist.
What am I missing?
Addendum: I guess an Aprilaire zone controller linked to 8870's would fit my concept. Sounds expensive, though. An 8870 in each zone? Egad. But the setpoint of each zone could then be controlled by CQQ/Elk, and the zone control duties minded by the dedicated zone controller.
What am I missing?
