steveseven
I have a DS1920-F5 ibutton and DS9094FS+ ibutton clip.
The ibutton fits into the clip naturally one way that has the serial number information facing down to the NEGative part of the clip. The other side of the ibutton has no information written on it, and has a wider outer edge on it. I have that side facing up to the clip on the (+) part of the clip. The ibutton doesn't fit naturally in the clip the other way.
I wired with cat5e to the clip as follows:
blue wire DATA WIRE to POSITIVE (+) on clip.
white/blue wire to NEGATIVE (-) on clip.
I believe(But, not positive) that the serial number side of the ibutton is the positive(+), so this doesn't make sense!
This diagram http://www.maxim-ic.com/quick_view2.cfm/qv_pk/2979 also shows the discrepency as the ibutton says NEG, and the ibutton clip (+) is touching this NEG side of the ibutton.
Can someone explain? I don't want to hook up until I am sure of correct wiring. Can't find anything on www.maxim-ic.com.
Thank you.
Thank you.
