Insteon In-LineLinc Dimmer vs. Micro Dimmer Module for LED dimming?
Aerie
I'm planning a new install and would appreciate opinions on these devices. Their spec sheets do not adequately address the intended need; that is, to control exclusively LED lighting in the forms of strips, surface mount fixtures (without bulbs) and recessed fixtures (without bulbs). I plan on installing either of these devices in a double gang box alongside a Keypad dimmer switch mounted on a single gang mud ring.
Dimming LEDs with standard dimmers kinda sucks. Smart bulbs and strips or fixtures with analog or digital dimming inputs are better.
Otherwise the only difference between those devices is supported wattage which is 25w or 100w of LEDs. Strips are only dimmable with these devices through a special transformer.
