apostolakisl
I have been having trouble with my lawn looking very yellow, chlorotic as the pros say. Anyhow, I started reading about how to have a healthy lawn and learned the importance of pH as it relates to ionizing the nutrients so that plants (grass) can get to them. The ideal pH for most grasses is slightly acidic (including mine).
I checked my lawn pH and discovered that it is quite alkaline. My water comes from a well which is a limestone aquafor. Lot's of CaCO3. Very basic. So I was reading that you can treat the water by injecting concentrated acid into the line as it is being consumed. I can't seem to locate a system to do this.
Any ideas on how to automate this setup. Of course it is very important to control the delivery of the acid so as to get a nice 6.5pH and not go too far and kill the lawn with acid.
I was thinking of using a medical IV pump to deliver the acid. This is quite easy to use and can deliver accurate amounts. The trick is how to link it to the flow rate of water so that it adjusts the output. Similarly, you could put a pH meter in the line and adjust the delivery to the pH rather than the flow rate.
