Latest firmware release for WC32
CAI_Support
We have released a updated version firmware for WC32. In this version, the change is to allow user to configure DS1307 present. In that way, users without WC32IO do not need to add pull-up resistor to their board.  There is no other change to previous firmware.
For wc32 board only, download from this link:
http://www.cainetworks.com/support/download/wc32update040214.zip
If you have custom GUI for your WC32 board, please find the factory GUI source here:
http://www.cainetworks.com/support/download/wc32guisrc040214.zip
Please remember always reload factory API using  /wc32api, after each time GUI updates.
WC32 can only be updated on 192.168.1.15 IP address. There is a README file inside the zip file, please follow that exactly.
Is it hard to implement cpu usage on our webgui? Maybe it cant be monitored....?
It could be very usefull to see how much ressource pic32 need during process.
On WebControl, CPU is always running at max speed or 100% usage. If one process did not use all the CPU slot, next process will start earlier to use it.
Realy?
Is it possible to overclock it? Pic32 is 200mhz speed right? Is it pissible to raise the cpu speed?
