hi all!!
First post here!
was linked by the great IVB from www.avsforum.com/CCQ forums
so here is a copy paste from a thread i just started over at diyaudio.com
hope some of you will find it interesting
I have ordered a few expensive pieces of LEDS
from Seoul Semiconductor
http://www.acriche.com/en/
wich are AC 120V driven direclty
( there are a 2 resistors on the pcb though )
I believe that they use the up and down of the AC
to drive and reverse/drive 2 different 1W section of the LED pannel, something like that ..quite simple
and that removes the complexity associated with LED electronics and voltage requriements ...
So that said , i now have 10 6500K
( was the only one avaiable by then) 4W ( 2 2W leds on each pcb ) "specialist" Acriche LED units @ 21$USD each from www.avnet.com
I will be receiving some 3000K version of the same leds this week for further analysis.
My point was to test the usability of leds for indoor lighting to replace annoying CFL bulbs and plain ridiculous incandescent light bulbs.
So i tried to compare them to what was available at the moment in my house to see how they could be used.
Here are a few samples of the tests i did for the interested of you.
1- 6X4W LEDS 6500K ( total 24W )dispersed on the ceiling VS 1 phillips daylight 27W CFL ( quality one @ 5500K)
Please do not mind the color temperature difference, i tried to attenuate it by using automatic white on my camera ....the camera was setup to give the best exposure that represented the actual scene as seen with my eyes.
27W CFL
http://img526.imageshack.us/img526/5530/dsc05398ho4.jpg
24WLED "star" setup
http://img526.imageshack.us/img526/6910/dsc05399eb8.jpg
following test was done at kitchen
2 led modules for 8W total were used VS
2 50degree halogen 50W spots
( please keep in mind here that the leds are 110degree patern, so there is no bright spot as seen with the 50degree spots ... thought i do not see it would be a problem if the leds were recessed in a cone spot enclosure ..to be tested )
2 50W halogen spots 50deg.
http://img526.imageshack.us/img526/1473/dsc05403lk0.jpg
2 4W acriche led modules
http://img182.imageshack.us/img182/6635/dsc05405db6.jpg
Now this test is again 2 4W acriche led module VS 3 30-40W candella type incandescent in a round mount under a diffusing white glass ornment
i'd say that the total light output was a little higher with the 2 leds than with the incans here ..
incandescent lighting
http://img526.imageshack.us/img526/5530/dsc05408br7.jpg
2 4W LEDs
http://img526.imageshack.us/img526/2987/dsc05409kq9.jpg
Again do not take care of the color temperature..
only brightness and illumination is in test here
I like what i've tested, and i will be investigating those new LEDs again much soon,
as i intend to use them in 80%+ of my future house lighting !!
What do you think ?
have you personally done tests with leds?
i know there are many more efficient modules,
but none has the retrofit possiblity and the easiness of those 120V AC units ..
Now onto the dimming subject ..
how do regular dimming control works ?
what do we want to control those leds?
i've read that LEDS are current driven units,
but they regulate their current depending on the feeded voltage ..do not know if those are of the same...
I'd very like to be ablet o test those leds with some dimmer, i'll try to purchase one this week end at the store to see how it works wiht the leds.
i've also read that some dimmers work by switching on/off at different speed so there is no power loss from dimming .
my ultimate goal is beeing able to use those leds with regular Z-Wave dimmers to setup automation correctly
neway, any info on dimmers for lighting will be appreciated!
First post here!
27W CFL
24WLED "star" setup
2 4W LEDs
What do you think ?
