I've converted all my lights to UPB sometime ago and looked for a UPB floodlight and never could find one.  I just lived with my X10 flood until it failed about a month ago.
I decided today to remove the guts and wire directly to the lamp sockets and wire it to a UPB switch. The guts for the X10 floodlight are all housed in the motion detector which is also X10 based and won't do me any good. Its the part that failed anyway.
I removed the adjustable arm from the detector box and mounted to my own PIR which was white, so I painted it black. The wire for the motion sensor goes directly to my HS setup which, as soon as I finish, will control the logic on when the light comes on with motion, etc..
All it all, it was not very difficult of a conversion. I did my best to separate the low voltage wiring from the high voltage wiring by running it through a separate hole in the box and wall.
Having the motion detector separate from the lights should give me much more control on when the lights come on and the timing of when the go out. Also the motion and be used w/o the light coming on.
Here are some pics.
Here are some pics.
