johnnynine
My ideal whole home audio solution would have the following:
The most common model is 4 or 6 source/zones with in wall modules to control volume and source via a CAT5 cable wired back to the amplifier. I am not able to use these due to a wiring error where my speaker wire ends at the home theater and the CAT5 from each in-wall volume control ends in a structured wiring can across the house.
My Alternate Concept:
Does anyone have any experience with the multi-zone capabilities of the Denon DRA-397?
Would the zone control be easy to use via IR... are the zone IR commands discrete or do you have to send a zone indicator command and then send your follow specific command?
What do you think about setting up a Denon DRA-397 plus a seperate amplifer for 2 zone output and using 3rd party rf remotes with an RF to IR receiver and an IR distribution block?
Also if the remotes aren't a good solution I see that Xantech makes some in wall IR based control pads that I think I could use as well.
With this unit, I think I would need a Global Cache unit to do any automation since it doesn't have rs232... but the price is good.
Any comments would be appreciated.
Johnny
- 2+ sources
- 2+ zones
- amplified output to speakers
- rf remote controls
- rs232 control
- all in one unit
Johnny
