I'm going to hang an LCD tv, and rather than just run the power cable through a hole in the drywall, I thought I'd do it right and put a receptacle up behind the TV.
I was thinking of using one of the powerbridge products, but given that that will still use one of my existing receptacles, and taking account of the actual effort and cost of those things, I figured I'd add a receptacle behind the TV.
On the plus side, there is a receptacle immediately below, so I don't need to cross studs or anything. Uninsulated wall. Running the romex should be easy (WILL be easy actually - I have pics of the walls before the drywall went up, so I know exactly what's in there
My question is more on the wiring side of it. The receptacle below is not the 'last' receptacle in the circuit, the romex comes into that receptacle, and then moves on to another. ... so what is the correct way to wire the new receptacle to that? I assume I can just use some pigtails or whatever and just tap into one of the sides of the existing receptacle (effectively wiring the new circuit in parallel - I figure this is how the receptacles supply power to the devices plugged into them anyway). Is this correct? I don't want to do anything stupid.
