Got a new AC system with an OmniStat2. I'm trying to better understand how the OmniStat2 determines if it cools at stage 1 or stage 2. From reading the instructions it sounds like its a simple decision based on how far the temp is away from the desired temp. 1 degree away and its stage 1 and 3 degrees away for stage 2. But it doesn't seem to be working like that.
I set it to 20 degrees below the actual temp. It started at stage 1, then went to stage 2 for maybe two minutes then back to stage one. Is this normal? I'm guessing its more complex that a simple temp deference. Anyway to force it to stage 2?
Thanks.
Thanks.
