I have a 3 car garage with a parking pad outside it. It faces a woods with driveway from the side so no other traffic to worry about (except animals). Currently have a couple under eave mounted motion sensor floodlight fixtures but am not completely happy with them. They stick on sometimes and have other issues. Looking at replacing the sensors with a single sensor to trigger all the fixtures. Have seen the Optex LX402 suggested in other threads. Would need to provide dawn to dusk and on time control with automation system. Currently using misterhouse with X10 but looking to go with something better than X10 that won't break the bank. That's really a whole other discussion... I have good access so could even use a wired control signal solution.
Mainly looking for sensor and mounting location suggestions. I am thinking one mounted near the middle should cover the area pretty well. One on each side, aimed inward, would give me the option to trigger on either or both depending on how well they detect. Might work best to trigger on both as when you are going directly toward one you are going across the field of view of the other. (would be good to detect people as well as cars but would also be more prone to false detection...) I could mount it under the overhang so it would be fairly well protected from the weather at about 10' height.
