twilo123
Vidcam Updates
(All Versions (Android, Blackberry, Iphone/Itouch/Ipad, Winmo)
Added support for:
Added support for:
Added support for:
Remote Edition
Relay Support
Beta 3G cellular support
Auto-discovery Box Feature
Added support for:
- Rugged CCTV DVR
- Elite DVR
- Speco SIP ip camera (jpg/mjpg)
Added support for:
- Everfocus (DVR Paragon, Paragon264, & Ecor264 Only. FW 1.2.11 or higher)
- Geovision DVR & Ip Camera
- fixed bug for some jpg codecs on certain models of vivotek and d-link
- fixed bug for large size video
- redesigned manufacturer list input box for search capabilities or scroll since the list of manufacturers is about 100+. so you have the search option now as well as scroll.
- added quality selection field (for api that support this variable)
Added support for:
- Submitted update for zoom icons as shown below. you can still pinch in/out for zoom but also have an icon option now. PT are still swipes
Remote Edition
Relay Support
- Setup & Control of Relays can be found under the 'devices' tab.
- You can add direct relay control or use the timer function to automatically switch a relay after starting it.
- Full tutorial can be found here: Remote Edition Relays Tutorial
- 3G cellular support although the commands run much slower with this method. best to use regular functions on wifi and 3g cellular for one-off controls like for remote lighting.
- In the Box setup area there is now an AutoDiscover button. clicking this button will automatically try to locate a box which is on the same network and populate the ip address automatically in the ip address field of that box setup. Just save the box from there.
- Full tutorial here: Remote Edition AutoDiscover Box Tutorial
