TS07
rfdesq
Has anyone noticed a strange software loop on their TS07? I finally hooked one up the other day and it's great. Here's the quirk. My Linksys router lost its lease and the IP address of the XEP changed therefore losing communication with the TS07. I figured out what was going on and tried to set the IP address of the XEP to fixed. When I got to a point in the programming an error screen came up and said the subnet mask was incorrect. It was set to 255.255.255.0. The screen asked if I wanted to continue and reboot the XEP. Each time I pressed No it put me into a loop and all I could do was say Yes and reboot the XEP. The reboot went fine and the subnet mask was correct but the XEP reported it originally as incorrect. I couldn't get back to the setup screen to check the subnet mask and confirm if there was a problem without doing a reboot. A reboot was inevitable and everything has been fine with a fixed IP address ever since. Did I have too much eggnog?
Edit: Maybe I did have too much eggnog. The loop may have been in ELKRP with a network connection. Either way the issue of a software loop is correct. I just might have been playing with the TS07 at the time also because of the lost communication.
