UPB Fixture module or remote load switch for new construction
robolo
I'm helping with a new construction project for a friend (really it's not for me) and we are planning to have a number of UPB switches homerunned to the mechanical closet and have 6 button scene controllers on the walls. I am trying to understand the benefit of using actual UPB switches in the mechanical room vs using wired-in fixture modules at the actual light itself. The cost for the wired-in modules are a little more and they are les accessible if need to be reprogrammed. That much I understand but is there anything else?
Would there ever be a reason in new contruction where you have access to everything and can plan all the wiring runs to ever use a wired in fixture module?
The only thing I can think of, is a wired in module would look better in a closet...not as strange as a wall of switches (someone posted one a while ago...I couldn't find the link).
Personally (not a professional installer), I'd put whatever was cheaper in the closet as no one is going to see them. Heck, you don't even need to buy face-plates, just use a plastic screwdriver to poke the buttons (if Web MTN or SAI) to get them into programming mode!
--Dan
Dan,
Thanks for the reply. Seeing that the wall switch is actually cheaper than the fixture module makes me think the wall switches are the way to go. I am actually planning to use 2 of the of the Pulseworx Lighting Control Panel units.
I'm just trying to make sure I was not missing the boat on some important aspect of the fixture modules.
Robert
Thanks Martin,
We bought the Pulsworx cabinets from you guys this past weekend! After seeing your post I decided to just go ahead and call your store and spoke with Ralph in tech support. He confirmed what I was thinking. During new construction it is best to homerun the fixture wires to a central location and use easily accessible load bearing UPB switches. That way you avoid trying to access a hard-to-reach fixture appliance module if ever need to reprogram.
Question....why home run all the wires? I don't see the point, as due to the flexibility of UPB's links, you could just have switches in every room, and then link them to another switch.
Or am I now missing something? I guess, what's the advantage to homerun all the lighting?
--Dan
