Another Newbie here.  I played with X10 in the past and I have a OmniProII installed thought not doing much.
I have had reliability issues with x10 signal propogation so I started moving to UPB.
I am now seeing a simliar issue with UPB
Checking my wiring this morning I see that I have the following installed as couplers/repeaters
1. CP000-1:1 Passive Coupler I think this was a X10 phase coupler
2. Leviton HCA02. IT says it is for Decora but I believe that it is a phaes coupler/repeater for X10
3. HAI 39A00-1 UPB Phase Coupler
I am trying to see if maybe I need a UPB repeater.
I have a i/o input module wired to a motion sensor so it sends a UPB Link on contact closure. When the OMP2 sees the link it then sends out some X10 to control some lights not yet converted to UPB.
I have UPStart setup in my kitchen (centrally located but maybe not on same phase) and I have it logging. Testing from the central location I can send the Links and all works fine for Link being activated/deactivated.
In the logs I can see that most of the time when the motion sensor trips it sends out the activate link. When the sensor stops seeing motion it should send a deactivate link and I am NOT seeing this in the logs.
So I light gets turned on but never off.
I think I there are 2 possible causes.
1. I/O module is not sending the deactivate link
2. It is sending but it is not strong enough to make it through to either the OMP2 or even the centrally installed PIM
I will try to eliminate #1 by moving my PIM closer to the device and monitor it from there to confirm it is sending the link properly.
Re: #2
Is it necessary to have a X10 phase coupler and a UPB coupler?
Would the x10 repeater cause any issues with the stength of the UPB signal?
Does the repeater repeat all PLC signals or would I possible need a UPB repeater as well?
Any other thoughts would be greatly appreciated.
Thanks in advance.
Re: #2
Thanks in advance.
