My house has a fairly sophisticated water cleaning system involving reverse osmosis for the entire house (water down here is REALLY bad). Anyway the waste water is stored in a tank and there is a double float system that operates a well pump inside once it has reached a certain level and stays on until the bottom float drops. Anyway I noticed the shrubs around the edges are getting brown and I looked and noticed the pump tripped the breaker. I turned it back on and it tripped immediately indicating a short on the motor. I was kicking myself in the behind because I knew something was wrong and I believe this has been going on for weeks.
I would like some way to monitor this. I purchased a water meter for this tank but it is analog. There is an overflow spout that I thought about putting a pan or something at the end and then putting a water sensor on there but if it rains it will trip. maybe a water flow sensor on the output of the pump and an water flow sensor on the overflow? The overflow is really a trickle so I don't know how particular or if those sensors exists. Any suggestions here? I thought also about CT's on the motor itself...
Thanks!
Neil
Thanks!
Neil
