C
chucklyons
Guest
I'd put this in the download section, but there seems to be an issue with being able to load a file less than 29mb.
If anyone wants this let me know - or maybe the moderator will read this and fix the problem.
WeatherUnderground v2.0
This is an update to 123’s WeatherUnderground Module. Included in this Zip File are 123’s Original Instructions. The same functionality that was included in the first version is retained, plus added some additional features.
Lunar Phases – Displays moon image with varying degrees of shadow, depending on whether Waning or Waxing Gibbeous/Crescent. Full Moon, New Moon, First Quarter and Last (aka Third Quarter) are also included. The module uses the Moon Age and Moon Illumination for WeatherUndergrounnd (already available in 123’s version) to derive the images
Ajax for Update button: This keeps the page from refreshing when requesting an update of the latest Weather.
Realistic Weather Images: Two additional Image files are included. 1) Style_14_High_Res. High resolution weather icons. They load relatively fast, but some may opt for the second file 2) Style 15 – same as the High Res files, but compressed using Tinypng (www.tinypng.com) . They load extremely fast!
mbRealtime: This is used for doing a div refresh of the weather icon I have loaded on the upper left of the browser. This requires a new drop of the Global MinibrowserFunctions, which will be coming soon. This will not affect operation of the WeatherUnderground module in the meantime.
CSS: The JQM relies heavily on Cascading Style Sheets (CSS). Unfortunately, that would require a new JQM CSS for each module update. WeatherUnderground 2.0 has an individual CSS, which loads when the weather page is selected. It doesn’t add overhead (or much) to the load time and prevents having to load a separate CSS when not a weather page. As it is included in the WU directory, it simplifies installation, as well.
