With conduit, you can wait and drop the wires after everyone else is done.
You should wait until after the electrician and plumber are done, to run LV wires and conduit. But yeah, the drywallers could conceivably put a screw through a wire or conduit. If you install the cables deep enough, drilling holes through the framing members a couple inches from the drywall surface, the drywall screws shouldn't be an issue. When it's close, use nail plates.
Conduit would be good for difficult retrofit cable runs. If you can get to the bottom or top of a wall, from a crawlspace or attic, it's pretty easy to retrofit, and the conduit would be a waste of money. But then you can't see where the line voltage wiring is, easily. Take photos before drywall.
Curvy conduit fills with fewer cables, when you run 1 at a time - keep that in mind.
