Anyone using this thing to control shades or blinds? If so, how many scenes per node is supported, can I send a command to open a rolling shade to x%, two way status, etc...?
Somfy Z-Wave ZRTSI RTS Interface
The Somfy ZRTSI 1870202 Z-Wave Universal RTS Interface is a Z-Wave bridge controller that resides as a node within a designated Z-Wave control network. It receives Z-Wave transmissions and converts them to motor control commands for Somfy’s full range of interior and exterior RTS wireless controlled motors. Each Somfy Z-Wave ZRTSI is plugged into an active electrical outlet and has sixteen (16) virtual Z-Wave nodes that correspond to sixteen (16) RTS channels. Each channel can control one individual or one group of RTS motorized window coverings.
Somfy Z-Wave ZRTSI Bridge RTS Interface 1870202 Specification:
• Allows Z-Wave controllers to Operate Somfy RTS Devices
• 16 Channels of RTS Control
• 16 Z-Wave Nodes so you can use multiple units for expanded RTS Channels
• Can be controlled with Z-Wave Only
• 65' RTS Range under optimal conditions
• Rotating Multi-position 4.75" Antenna
• Plugs into Wall Outlet
• Dimensions: 2.2" W x 4.1"H x 1.55"D (Not Including Plug or Antenna)
