Hi guys,
I would like to know your opinion on a project that I wish to begin this september. I want to monitor 5 vacuum lines with the webcontrol board. Each vacuum lines are at 1 km from each other. So I'm planning to use more than 1 board.
I found my vacuum sensor : ( MPXV6115VC6U )
http://www.digikey.ca/product-detail/en/MPXV6115VC6U/MPXV6115VC6U-ND/951851
The question is how could I use more than one board and merge data in a mini webserver and have an ethernet display of the data.?? Is it possible to use board as slave/master
Is it a good idea to use something like a Raspeberry PI #B. as a webserver??
An other question is : How do I calibrate the vac sensor with the analog input from the board???
(ex : - 5 psi = ''236'' analog value.) Then ''236'' should display -5psi in my screen.
Please give me ideas!
Any helps will be appreciate!
Thx
Thx
