I have two analog inputs that need to be wired to a webcontrol board. I'm a little confused about the wiring. I know where the analog inputs go, but my question is the power and ground. The board has one power pin. Do I use this power pin for both sensors? According to the documentation, there are three analog grounds and one pin that is labeled just GND. Should I use the analog grounds for each sensor?
Sensor1:
+5 = pin 13
GND = pin 14
Input = pin 1
Sensor2:
+5 = pin 13
GND = pin 15
Input = pin 2
Should I use the same ground for both sensors like I am with the power?
ex:
Sensor1:
+5 = pin 13
GND = pin 4
Input = pin 1
Sensor2:
+5 = pin 13
GND = pin 4
Input = pin 2
Sensor1:
+5 = pin 13
GND = pin 14
Input = pin 1
Sensor2:
+5 = pin 13
GND = pin 15
Input = pin 2
ex:
Sensor1:
+5 = pin 13
GND = pin 4
Input = pin 1
Sensor2:
+5 = pin 13
GND = pin 4
Input = pin 2
