The Leviton RC-2000WH Omnistat2 with XSP is very reliable and multiple thermostats can be hooked together. I wish that Elk would read the outside thermostat and humidity.
I used an ELK temperature interface to monitor outside temperature and used multiple Aube hydronic thermostats as well as Aube for my main thermstat controlling a heat pump. What was useful about the Aube is that they take a 12v input (output from ELK) to trigger a preset vacation temperature setting. You do not have full control of the thermostat, but once you know what your vacation setpoint is you likely will not need to change it.
